Running pre-compiled binaries in GDL
Имеется модель EW-FAC (https://github.com/VTMIST/EW-FAC), написанная на IDL. Модель поставляется в бинарном формате. Я пытаюсь запустить EW-FAC при помощи GDL. Файл не запускается и не выдаётся никаких ошибок.
Я никогда не работала ни с IDL, ни с GDL. Как я могу запустить модель EW-FAC, поставляемую в бинарном формате при помощи GDL?
2 Replies 2
Hello gostevaad,
You should express yourself in English on this forum.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Yes, English only please.
This is the translation...
There is an EW-FAC model (https://github.com/VTMIST/EW-FAC) written in IDL. The model is supplied in binary format. I am trying to run EW-FAC using GDL. The file does not start and no errors are reported.
I have never worked with either IDL or GDL. How can I run the EW-FAC model supplied in binary using GDL?
Apart from the fact you mention GDL, I don't see any reason you would want this in Archicad.
Please explain more about what you are trying to do or this message will be deleted.
