Jochen Suehlo
Disable Lable UI
I read it anywhere, but I can't find it anymore:
Is there a way to disable some of the standard UI panes of the label tool by GDL commands?
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
5 Replies 5
I think the only panel in the Label Settings Dialog you can affect by GDL commands is the "Symbol Label Custom Settings" panel. What you see there is defined in the User Interface Script of the Label.
Jochen Suehlo
Thank You Laszlo,
I found it now: it is in the compatibility options, see image.
It disables the Text Style Tab
Dominic Wyss
Hi Joachim
There are many other UI elements that can be controlled via optional fixed named parameters. Especially frame control and orientation options:
http://gdl.graphisoft.com/reference-guide/parameters-for-labels
Dominic
AC27 CHE - macOS Ventura M1
runxel
But how can I prevent the label of having a pointer?
You cant just LOCK "LABEL_HAS_POINTER" (or hide).... even with the option Jochen found above.
Peter Baksa
Sorry runxel, that's not possible. You can give a 2d text feedback to the user to please turn it off or on.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
