2015-05-14
		04:12 PM
		2023-05-23
		04:37 PM
			Rubia Torres
2015-05-15 11:47 AM
christop wrote:The example add-ons will only load if you run ArchiCAD as a demo, i.e. no active licence or keyplug. If you're running it licensed, you won't see anything. Also, check the Add-On Manager to see if the add-on is loaded.
Hi
I compiled the apx and loaded it through the Add-on Manager.
But I dont see any additional panels. Where are these panels visible?
On another note, just to verify that it cant be done. I have not found a API function which allows to add a parameter programmatically so that its visible in a library parts Custom Settings panel. Can you add parameters only through the GDL editor manually?
2015-05-15 12:57 PM
2015-05-15 02:58 PM
christop wrote:Do you need to show the panels in
The Panel_test example compiles and is loaded through the Add-ON manager without a problem. I just dont see the additional panels, where would they be displayed..... I was interested in creating custom panels in the settings dialogs.
2015-05-20 04:29 PM
