2022-02-15 08:17 AM - edited 2022-02-16 12:17 AM
Hi All,
I am trying to make some edits to a Section and Elevation marker to remove a portion of the Layout Sheet ID from being displayed from the section marker.
I'm using the following code:
layoutid = "<MARKERSHEETNUMBER_R>"+AC_DrawingGUID
trim = STRSUB(layoutid,18,STRLEN(layoutid))
TEXT2 5,0, trim
But instead of trimming the sheet name from NSPS-FTA-D-ZZ-DR-A-3001 to A-3001 I'm getting ER_R><NULLGUID><NULLGUID><6A3C429-0F99-4FB0-B356-1C8AF7E2447A>
I'm guessing the script is not computing what the sheet name actually is until it tries to draw it on the sheet and instead i'm just performing the STRSUB on the autotext instead.
Is there any way to achieve what I'm trying to do?
Thanks,
Scott
Solved! Go to Solution.
2022-02-16 11:25 AM
Autotexts' content are not visible in GDL, they can't be modified.
2022-02-16 11:25 AM
2022-03-04 07:58 AM
Thanks Peter. That was what I feared.
