Sonne26
How to make GDL objects automatically cut by walls, beams, columns and slabs
In GDL,   is there a method to automatically cut the GDL object like the AC native component?
1 Solution
runxel
Nope, not possible.
Depending on the scripting an object can take part in line elimination, but thats it.
Sadly they can't take part in a merge (only possible to merge something to roofs, shells, or morphs).
So I see no possibility at the moment to let an object take part in priority based bmat connections.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Go to post
runxel
Nope, not possible.
RandyC
 No automatic way but you can convert the object to morph - then make your cuts
and resave as object if you want.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
