Mats_Knutsson
Mentor
Simple stylish 3d tree object?
Hi, what would be the best geometry to program a simple 3D tree kind of  the examples in attach?
I'm looking for something with parameters that I can randomize to get a slightly new geometry for each instance.
Br,
Mats
AC 25 SWE Full
19 Replies 19
Jim Allen
Here is the link to a pln file with an initial object and the raw geometry.
https://drive.google.com/file/d/1hj8YViCwINr2RhPDI02FS3ufWTt6E_Mc/view?usp=share_link
Mats is looking at making some objects over Christmas.
His wife will be happy...
Archicad 28 UKI | OS X 14.7 Sonoma
Mats_Knutsson
Mentor
I looked at the code but didn't understand it. Instead I played with another concept... Treetime . Needs a few more tweaks.
EDIT. I tweaked a bit https://youtu.be/kZG4XRIMGXE ... I skipped gym. This was more fun.  Doing progress but still looking lollypoppish... got the rgb but will probably use a handful of chosen rgb's not to be surprised by ugly colors....didn't get masking out contours (when they are checked in 3D styles).
AC 25 SWE Full
Mats_Knutsson
Mentor
AC 25 SWE Full
Mats_Knutsson
Mentor
The massivator is cool. I've tried it. I think I'm close in something further dow in this thread.
AC 25 SWE Full
Mats_Knutsson
Mentor
Hi Miha :). That object looks interesting. Mind sharing it? We should have the same libs as germany but obviously not... /Mats
AC 25 SWE Full
hevi
Ace
I was on the same search a while back as I lacked a suitable low poly tree/hedge object for site models / scale reference. I'm currently getting by using the in AC simplified geometry from Escape assets (example here) which lacks parametricity.
I came across this app from Dr. Andrew Marsh which is truly awesome with an effective and intuitive approach to geometry generation. Unfortunately it is provided under a non-commercial license, and I haven't been able to get in contact regarding possible commercial use.
Jim Allen
Andrew Marsh builds some fantastic tools, but his complex trees will be too heavy in terms of polygon count, and you can get better results from something like NGPlant. I've built lots of realistic plants with that, but poly count is an issue.
His simple trees might be ideal though.
AlexKyWe
Hi! Its a long shot since its an old post but do you have any recent links which I can use? This image is exactly what I am looking for in Archicad! 🙈 Cheers!
Jim Allen
How about this?
Happy to share the gsm file. It has a 2d representation (simple shaded circle) and a 3d one.
As with all my GDL objects - modifications/improvements are actively encouraged!
Jim Allen
Object attached.
It could be improved with better hotspots (particularly for scaling in 3D) and making the object scaling more consistent between the 2D and 3D elements. They are kind of okay, but I'm not very good with hotspots!
