GDL
SOLVED!
When I use the check script, I get this error.
LeeJaeYoung
IF WALL_SKINS_PARAMS[i][6] = 3 THEN
• [6] core status
core status: 0 - not part, 1 - part, 3 - last core skin.
AC27 on window 11
1 ACCEPTED SOLUTION
Solution
DGSketcher
Legend
This is generated when using = to compare REAL values. It works with INTEGERS but GDL is prone to false results for Real values due to precision.
The usual workaround in your coding is:
EPS = 0.0001 !or some other small value to suit your object
IF ABS (WALL_SKINS_PARAMS[i][6] - 3.00) < eps THEN...
this way if the divergence between values is less the EPS then the result will be TRUE, and any value greater than 3.00 will be FALSE
6 REPLIES 6
Solution
DGSketcher
Legend
So is this real value?
I understand it as an integer....
Is INT(WALL_SKINS_PARAMS[i][6]) = 3 ok?
AC27 on window 11
You would expect the core to be an integer (0, 1 or 3), but because WALL_SKINS_PARAMS can also tell you the skin thickness, the entire parameter is probably treated as a real number (just my guess).
So the core value (although it may be exactly '3') is also treated as a real number, which means it could have a decimal precision.
You are then trying to compare something that may have a decimal precision with something that does not - hence the message to say "Use of real types can result in precision problems".
In this case it is just a warning and can probably be ignored - you will only see it when checking the script.
Or it is a case of scripting as DGSketcher suggested to allow for a small decimal range (error).
thank you so much
AC27 on window 11
In this case, when the stored value is surely an integer, round_int might be easier to read.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
@Peter Baksa Thank you for your guidance. I had forgotten that option. Might need to review some of my coding... 👍
