GDL
Working together with the Global Library Archicad 28
Jeroen
Hi All,
I am working with the new Archicad 28 and I would like to have my own library package fit into the folder structure of the regular library.
So I changed the PathNamesTables, the FolderNames and so on, but the test-object still appears in the original folderstructure of the LCF.
How can I fix this?
with  kind regards,
Jeroen
3 REPLIES 3
Peter Baksa
Hi Jeroen,
Each file in the .libpack has to have a pathnametable entry (even pathnametable...json) for this to work.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
Thanks, I will try it and I hope it works for me.
But I will try it later because right now, I am looking for Manitoba online casinos sites and I found https://onlinecasinomanitoba.com/ website link. When I am done playing after that I will try it and will update you.
Jeroen
I found the solution,
After each entry there is a comma, but on the last one there should not be a komma
Also be aware that it won't work when there are 2 identically named objects (even in different folders)
