GDL
World Coordinate object issue
strangeday
Hello everyone, using the world coordinate object I'm encountering a little problem(or limitation of the object itself), I'm unable to show more than 2 decimal after seconds(even if I set 4 decimal in project origin), I try to change working unit and tollerance, but nothing changes, do you think there may be a way to overcome this problem??
Thank you in advance
ps. added a screenshot to be more explicative
Francesco De Meo | Architect | AC 6.5-28 | Latest build | Win 11 Pro 64 | AMD Ryzen9 9950 | 128 Gb RAM | ZOTAC GAMING GeForce RTX 5090 32GB
5 REPLIES 5
Unfortunately this object doesn't have this option.
Your alternative is to edit it and change some code.
If you are confident with GDL code, the workflow is:
1. Find in your AC24 Library a Macro called "coordinateDim_m";
2. Open it and go to the 2D script and replace:
This 2 lines:
	text_x_coor = LONG_LETTER + " " + STR(LONG_DEGREE,1,0) + "° " + STR(LONG_MINUTE,1,0) + "' " + STR(LONG_SECOND,3,2) + "''"
	text_y_coor = LAT_LETTER  + " " + STR(LAT_DEGREE, 1,0) + "° " + STR(LAT_MINUTE, 1,0) + "' " + STR(LAT_SECOND, 3,2) + "''"
With:
	text_x_coor = LONG_LETTER + " " + STR(LONG_DEGREE,1,0) + "° " + STR(LONG_MINUTE,1,0) + "' " + STR(LONG_SECOND,5,4) + "''"
	text_y_coor = LAT_LETTER  + " " + STR(LAT_DEGREE, 1,0) + "° " + STR(LAT_MINUTE, 1,0) + "' " + STR(LAT_SECOND, 5,4) + "''"
I think this will do the trick.
strangeday
Hello Mr. Braza..... ......I have no words to thank you!!!...your suggestion saved me a lot of time!
Thank you again
Francesco
You are welcome Francesco.
Anarchiteckt
Helle Brazza
I follow your instruction.
I could find the Macro and replace the GDL code.
[list=]
  • BUT it´s still a problem. I don't have the right to save the change.The Macro is just "read only"
    [list=]
  • For your information is the library on a bimcloud basic.
    How is the procedure to unlock this macro?
    Best Regard
    Gwen
    Gwenael Tripodi, Architect | BIM Manager
    AC 8.1-26
    MacOS Big Sur | 3,8 GHz i7 8Core | 24GB | AMD 5500 XT
    Hi Gwen,
    It looks like your library is compacted in a .lcf file. If it is the case, then you will have to extract all the content of the library to a dedicated folder and finally get access and edit the "coordinateDim_m" macro.
    Hope this helps.
