parameter buffer in macros
Hi!
I would like to use macro and i would like to "transfer" several values to the macro. Is there any way to just tranfer a parameter buffer when using a macro??
for example
main 3D script:
put 0, 0, 15,
a, 0, 15,
a, b, 15,
0, b, 15 (etc.etc)
call "cprism_creator" parameters all
cprism_creator script:
cprism_ top, bottom, side, nsp/3, h, get(nsp)
runxel
This is exactly how it works.
There can be only one buffer, so a macro will have the same stack as the main object, and can modify the stack.
