yesterday
Hi there
Today a really easy question, but I can't find the issue. The following script;)
block a,b,zzyzx
I said it's easy, but when I save it, I can not edit the block in 3d. Actually I can change A and B, but not zzyzx... threw the dialog it's working. I've the same problem in Archicad 27 & Archicad 28... any ideas?
But... when I select two or three elements at the same time, it's possible to change the heights...
2nd topic: You see on the right side a block created in Archicad 28... no hotspots generated, eather with the chechbox. In the middle you see a block created in Archicad 27 and migrated to Archicad 28... same settings.
Thank you for your help, I think the solution is really easy and I don't see the checkbox.
18 hours ago
Maybe share your object?
#2 Check to see if the Bounding Hotspot toggle is active under the Compatibility Settings from the AC28 object.
AC22-28 AUS 3001 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
10 hours ago
No issues with block a,b,zzyzx on new objects in AC 27 and AC 28 on MAC.
The zzyzx hotspots are there and the object is vertical stretchable.
I did not change anything of the default settings in the Compatibility Settings.
Which Windows version are you using?
5 hours ago
4 hours ago
The Block 28 has no 2D Script.
If you add for exampel PROJECT2 3, 270, 2 then you will have all hotspots.
The Block 27 works for me in both versions well.
4 hours ago
For what it is worth, the 27 version uses a Prism command, the 28 version uses Block.
The Cube object from Graphisoft uses Brick. It also has an Easter Egg for a Rubik's Cube, but I couldn't understand the logic in the Master Script to get it to show up.
