gaba
how many parameters in one library gdl object: 500,1000... ?
technical question: is the number of parameters in one library object somehow limited, e.g. to 500, 1000... parameters?
"When you seek knowledge, you will eventually find it. Then you will become its source - until such time as you must seek it again."
AC 7 - 29, Twinmotion | Windows 10 Pro for Workstations
Dell 7740 Xeon | 128GB | Quadro RTX 5000 16GB + LG 2560x1080
1 Solution
runxel
If that hasn't changed it is still 1024 parameters max.
Some windows / doors are very close to exhaust that. But all in all I think it's reasonable.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Go to post
runxel
gaba
runxel thank you
