Betencorte
Import RFA as GDL Object password
So, i have downloaded a RFA model and imported with the command "Import RFA as GDL Object...", but the gdl object have some wrong parameters, well, i did open the object, but it was password protected, is that password commom for all RFA objects? Is it specific? Is there a way of editing the object?
1 Solution
I have never known the RFA to GDL import to set a password.
But if there is a password then it is not a default one as far as I know and I have no idea how it got there.
Unless the RFA object had a password in the first place?
You will need to know the password to edit the object.
Go to post
3 Replies 3
Betencorte
Yes, maybe the password came from the rfa file
scottjm
Mentor
According to this article dated 2023 it is not possible to password protect a revit family. 🤷
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-How-to-make-...
