Ady84a
property’s value in UI as a parameter
In the tutorial Displaying Properties with Labels it states that "While the chosen property’s identifier can be stored in a parameter, make sure you never try to save the property’s value as a parameter."
https://gdl.graphisoft.com/tips-and-tricks/display-properties-with-labels
Is there any other way to store the property’s value from the n = REQUEST ("Property_Name", myProperty, _typeName, _groupName, _propertyName)
so that I can export the result to other Programs
Thanks.
1 Reply 1
Peter Baksa
Hi Ady84a,
Not through labels, but a schedule can list properties of the elements and export the result.
An element can have multiple labels, so quantity-like properties couldn't be exported reliably that way.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
