‎2021-01-14
07:25 PM
‎2021-09-14
01:29 PM
Noemi Balogh
‎2021-01-14 11:06 PM
‎2021-01-15 01:02 AM
‎2021-01-15 12:39 PM
Is the data populating parameters in the parameter list or just local variables in the master script?- Yes, the data from the txt-file are the value of the parameter "rkv_id", which will be exported to dwg-file into a attributed block.
‎2021-01-19 12:14 AM
Is the data populating parameters in the parameter list or just local variables in the master script?If you want the 2D representation to update without having to run the parameter script then you need to set it as a local variable in the master script. The way it seems to work is that the master script runs every time the view is refreshed (because the master script runs before every other script (such as the 2D which runs when the 2D view is refreshed). the 2D view is refreshed every time you pan or zoom, so very often.
rkv_id = text-file-value parameters rkv_id = rkv_id
‎2021-01-19 12:20 AM
‎2021-01-19 12:25 AM
