GDL
"zsh: permission denied:" when trying to use the LP_XMLConverter tool on mac
MetalFingerz
I'm trying to extract some .gsm to .xml using the LP_XMLConverter tool on my M1 Pro (running Monterrey 12.2.1). I've been trying with AC 21 or 24 and have had the same error every time :
zsh: permission denied: /Applications/Graphisoft/Archicad XX/Archicad XX.app/Contents/MacOS/LP_XMLConverter.app
(XX being the Archicad version)
I have a windows laptop where I have no issue using the terminal with the tool but I would like to avoid doing to much back and forth between laptops on the current project I'm working on.
Any advice to bypass or fix this error on my mac ?
Thanks.
Peter Baksa
a Mac .app is just a folder, you need to use
Archicad XX.app/Contents/MacOS/LP_XMLConverter.app/Contents/MacOS/LP_XMLConverter
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
4 REPLIES 4
Peter Baksa
Péter Baksa
Hello Peter,
I changed the command in the terminal and now I'm getting this error instead 🙃
zsh: no such file or directory: /Applications/Graphisoft/Archicad XX/Archicad XX.app/Contents/MacOS/LP_XMLConverter
When I drag and drop the LP_XMLConverter file (folder ?) in the terminal, it ends with the ".app" extension.
Should it be
/Applications/Graphisoft/Archicad/Archicad XX.app/...
Péter Baksa
That was it. I should have read your reply more carefully... 😅 I didn't realize you went inside the first LP_XMLConverter directory because that was where I stopped.
