GDL
retrieve the dimensions of a dialog
Hello,
I use the function DGGetDialogSize() for retrieve the size of a dialog palette, but the function doesn't work
This is the syntax -> "DGGetDialogSize(cntlDlgData.dialID, DG_ORIGFRAME, NULL, NULL);"
The function appear when I initialize the palette
Can anybody help me ?
Thanks
4 REPLIES 4
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
The third and fourth parameters are pointers to the width and height of the given dialog. If either of these pointers are NULL, that value is not returned.
You should use the function like this:
short width;
short height;
DGGetDialogSize (cntlDlgData.dialID, DG_ORIGFRAME, &width, &height);
Regards,
Tibi
Thanks for your response.
But I have already try this method and no success
I don't understand why...
Ok I found a solution.
I have export my preference and the palette have the good size.
Thanks
Hi guys,
So I have the same problem, I use the function DGGetDialogSize() and I have delete "preferences" folder (x86). But this time the modal dialog don't change her size...
Any idea ?
