Lingwisyer
Guru
uI_listitem - Loops
Hi All,
Does ui_listitem not work in loops? I am only getting a single item...
FOR i = 1 to 10
	ui_listitem{2}	i,	1,	array[i][2],	1,	""
next i
array[1][2]
And if there is someway to get it to work, is there a way to set the paramDesc to an array?
Ling.
1 Solution
Lingwisyer
Guru
User error. My loop was starting from 1, so it was conflicting with the header...
Go to post
Lingwisyer
Guru
