2004-03-14
04:29 PM
- last edited
2 weeks ago
Molinda Prey
2004-03-14 06:21 PM
paulw wrote:Forget AllPlan; the other two are the only ones that fit the bill.
I am on the verge of jumping ship from 2d AutoCad, and I am looking at either ArchiCad, Revit or Allplan.
paulw wrote:If I were you, I would look around me and visit people who already use any of the listed. Pick their brains a little. Go through the list of the registered users here (quite a few Reviteers too) and see who is in your geographical vicinity.
I mainly get involved in small domestic and commercial extensions and alterations in the UK. Nothing extravagent, just normal traditional stuff really. Workload is increasing, and I would like to be in bed before 3AM, and have weekends off too!
paulw wrote:Plain vanilla ArchiCAD should do all of the above; for really good rendering, download the (still) free public beta of AV Works at www.abvent.com - there is a thread in Rendering and Multimedia forum.
I suppose I want more automation (timber roof layouts and schedules etc), and less repetition (move a wall in one view and not having to alter 2 or 3 plans and 4 elevations). Clients seem to want 3d renders too, ( I currently use Sketchup for this), so good accurate 3d images would be nice.
paulw wrote:Because you like it better? Because it is easy to use? Because there is a experienced friendly soul near by that you can call when you get stuck (as you will, don't worry ... whatever you choose).
So really, I just need to know why I should pick ArchiCad instead of one of its competitors?
paulw wrote:The worst point, again in using any new software, is you. Or me. What you know and what you are used to is always easy, what you are learning is hard and the old stuff is sooo tempting ... but don't.
I know the good points, but what are the bad points?
paulw wrote:Not on your own. The way of working is so different, that at first it will be totally confusing. You already have made the decision, now the implementation - invest in good training and consulting, have someone lead you through the first project. That's it. And, true for all of the mentioned.
One major consideration, is that I need to get accustomed to working with a 3d model, so I not only have to learn the software, but also adjust my working methods. Any idea of how long ArchiCad will take to actually learn and for me to become proficient? Can I just get stuck into it and produce drawings quickly?
paulw wrote:It would be best if your fellow UK pracititioners chimed in. One of the strong points of ArchiCAD is that it is not hard wired for a market, and can be used anywhere in the world, with all the unit systems etc. The special tweaks are also available for special markets, but AFAIK in the UK you get International, which I am using here in the UAE and used to use it back home in (was then) Yugoslavia - no problems.
If anyone has had to make a similar choice, then I would be really interested in why ArchiCad was chosen.
2004-03-14 11:25 PM
paulw wrote:May I ask why you are jumping ship from 2d AutoCAD and not considering 3D AutoCAD? If you aren't using AutoCAD LT, you do know that you have 3D tools already, right? Many of the features that ArchiCAD users tout are available with AutoCAD, if you know how. For example, if you build your AutoCAD model in 3D, you can view and edit the elevations in paperspace.
I am on the verge of jumping ship from 2d AutoCad...
2004-03-15 09:47 AM
2004-03-16 09:46 PM
2004-03-17 09:01 AM
paulw wrote:ADT is also capable and it's future will at least be certain for a few more years to come. But it is a complex beast and I much prefer ArchiCAD (and Revit). ADT2004 is much better then the previous versions and inherited quite a few Revit-interface concepts.
Thanks for those very detailed replies.
I will have to spend a bit more time reading them and taking the information in, so I'll have to post more later.
I have not considered ADT, as from what I've been reading it may have little future, so I don't want to invest time in getting to learn it if this will be wasted. Plus, it seems a bit of a 'make do' program as apposed to the others parametric based concept.
2004-03-24 11:30 PM
2004-03-25 05:55 AM
paulw wrote:No, you will not. ArchiCAD pans and zooms with the scroll wheel jsut like the mentioned.
The pan and zoom of AutoCad and Sketchup are excellent. I would certainly miss this.
paulw wrote:Autosnap of course.
Also the Autosnap and auto align of these are important.
paulw wrote:Well ... first of all, you are NOT moving around the drawing, but around a virtual building. That concept has to be grasped; you are NOT working with a drawing at a time, but with the whole 3D model plus all the data.
As are the keyborad shortcuts - L for line, m for move etc. Does working with ArchiCad match these for speed of input and moving about the drawing?
paulw wrote:Leaders are there (label tool) but the text formatting has quite a bit to be wished for
One thing I like on all my drawings is comprehensive descriptive text of what is what and where it goes, with leaders as required. Is this a problem - does text have lots of formating options?
paulw wrote:PlotMaker - organize and be a stickler as much as you like
I am a bit of a stickler for detail accuracy and positioning of things on my prints - even when at small scales or when it is not really required for the final print. So, are there any issues with layouts or detail printing? Some minor irritation could easily become a major one for me!
paulw wrote:By ALL means get at least the basic training. It might seem not needed, but conceptually you need some handholding in the beginning. It is not about "you click here and then it does this", it is about the work approach and setup. THAT is important, and is best brought across by an experienced user. Blundering on your own can create misconseptions and wrong perception that might harm the ROI.
Would it be possible for me to learn the essentials from the online training files, enough for me to start drawing? I was thinking of getting training in the products before purchasing. I wondered if this would be necessary for ArchiCad as the help files look quite comprehensive.
2004-03-25 07:28 PM
Djordje wrote:Virtual Building: Semantics. You still work with drawings and frankly AutoCAD is a bit quicker. Keyboard entry is MUCH better in AutoCAD, especially since you can customize everything. But keep in mind that you only have really two files in ArchiCAD/Plotmaker: a layout file and a drawing file. This minimizes opening times and switching back and forth between files. There's a trade off.paulw wrote:Well ... first of all, you are NOT moving around the drawing, but around a virtual building. That concept has to be grasped; you are NOT working with a drawing at a time, but with the whole 3D model plus all the data.
