2026-07-14 07:23 PM - edited 2026-07-14 07:24 PM
Hi everyone,
I recently started testing Archicad 29 (coming from Archicad 28) and I am noticing the exact same performance issues I experienced with the last two versions (27 and 28): Archicad occasionally becomes slow and laggy when zooming (in or out) and panning in 2D.
The lag seems to worsen the longer I work on a file, or right after taking a short pause. Crucially, this does not happen at all in the 3D window. The 2D zoom and pan feel noticeably slower when my mouse hovers over an object, or when I pan towards complex hatches or dense areas of the building.
As mentioned, I had this exact issue in Archicad 27 and 28. I previously created a thread about it, and a user named "MASz" kindly solved it for me. The workaround was to open the Registry Editor and change the RenderingAPI value from 0 to -1 under: Computer\HKEY_CURRENT_USER\Software\GRAPHISOFT\Archicad\Archicad 28.0.0\Graphix
(Here is the link to my old thread for reference: https://community.graphisoft.com/t5/Installation-update/ARCHICAD-27-Slow-zoom-and-pan/td-p/603267)
ARCHICAD 27 - Slow zoom and pan
However, in Archicad 29, changing the RenderingAPI value to -1 does not solve the issue at all anymore. Instead, it just makes all the 2D lines appear much thicker, and the lag remains. The lag is not as bad as in Archicad 27 and 28 before the changing of API value, but it's enough to annoy me when I work all day on a single project...
To be honest, I am getting very tired of fighting these same display performance issues year after year with every new release. It is incredibly frustrating, especially given that I am running a high-end workstation:
CPU: Intel Core i9-13900KF
GPU: NVIDIA RTX 3090
RAM: 64 GB
Storage: High-speed SSDs
OS: Windows 11 (with latest Studio Drivers)
Is the GDI/legacy engine (-1) completely gone in v29? And more importantly, is there any other way to get a smooth 2D navigation back on modern DirectX engines with high-end GPUs?
I would deeply appreciate any advice or help on this.
2026-08-07 01:43 PM
Hi HK,
I am experiencing the exact same issues with Archicad 29. I had the same issues with version 28 and it was actually your previous post that fixed it! Changing the RenderingAPI value from 0 to -1. I tried the same with version 29 and it does not solve the problem. It also makes it look almost cartoon like.
I haven't come across a solution to the issue yet!
Friday
Hi RTCadsolutions
Thank you for your reply. The previous solution of changing the RenderingAPI value from 0 to -1 no longer works on Archicad 29 and gives the lines a "cartoon like" appearance. I have installed the latest Archicad 29 update. The slowdowns during 2D zooms and pans persist. The issue remains unresolved despite using a high-end workstation that includes an RTX 3090. Please share any new workaround if you find one.
Friday
I don´t know if is the case, it´s a silly tip but: Have you tried to hold "SHIFT" then zooming?
Saturday - last edited Sunday
Have you checked the mouse polling rate?
Try to set this at 125 if you are using additional mouse software like Ghub or Razer.
Also be sure about the usb speed you are using and the mouse windows settings:
1. The Windows Baseline (The 6/11 Rule) While G Hub is running, the Windows speed setting must not artificially scale your movement.
Navigate to Settings > Bluetooth & devices > Mouse > Additional mouse settings.
In the Pointer Options tab, place the speed slider exactly at the 6th notch (dead center out of the 11 available positions). At this position, Windows applies a 1.0 multiplier (1:1 raw input), allowing the G Hub DPI to dictate the true speed.
Ensure that Enhance pointer precision is strictly unchecked.
yesterday
Thanks for the message and advices !
Unfortunately, i tried all of these steps and it does not work..
