cinda1212
Graphisoft Community (US) *not* (INT)
Please tell me how to get to the US Community, not the international one!  My user ID and login show US at the top, but when I go to Learn or Knowledge Community through ANY link, it switches to International.  This means that the learn templates are downloaded in metric, not imperial.  I can't figure out any way to switch it, or even FIND the US/English Imperial community.  Thanks!
2 Solutions
As far as this Community is concerned, there is no US, only International (for all English language speakers), German, Japanese, and Brazilian (Portuguese).
I am not sure about the Learn Portal as I have only ever downloaded metric files.
Check your user profile (top right of Learn page), go to INFO and see that you are set to USA.
If the downloads do not offer Imperial or Metric (I am not sure if they are supposed to), you can alwaye change the dimension units and working units when you have the file open in Archicad.
There really is no such thing as an Imperial or Metric file, it is just the settings in Archicad.
Of course that will not change what you see in the explanatory videos.
I am not sure if they are made in both Imperial and Metric.
Maybe someone from the USA can enlighten us on that?
Go to post
Marc H
All sounds correct from what I see going into GS Learn.  Starts out US on the log-in (and in my profile shows GS North America), then shows INT once logged into Learn and no USA choice.  Seems reasonable to have the platform aligned by language, not country.
On the 'templates', the only ones I see are transition templates from older versions (at a cost).  As you stated, setting your units to Imperial in your template is key.
Cinda:  This forum is for all GS AC customers, so you are in the right place for Community exchanges. I believe any files or objects you import into your AC workspace are respective of the units you set in your PLN Project Preferences.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Go to post
4 Replies 4
Marc H
cinda1212
Thank you both for your comments.  I'm glad to know that I didn't screw up somehow!  It seems weird, though, that on some screens it says US at the top, and others say INT.  My 'info' page correctly lists US.
The downloads I got from the lessons came in as metric...  so it would make sense that they START the intro to archicad lessons with "to change units do this...." but they don't.  No worries now.
Thanks!
FYI: On the Learn Portal, if you click you name in the Top Right corner, it will take you to your Profile.
Then on the top left, click Settings, and on the Settings Page, find the Language field where you can set your preferred language. This setting will be valid only of the Learn Portal, though.
