General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Is there a keyboard shortcut to deselect all (reverse of CTRL+A)?
Fisher
On the floor plan when the arrow tool is selected in the toolbox, I can select every element on the floor plan with CTRL+A. It's a typical floor, that I want to copy+paste to floors above, avoiding some elements. After selecting all elements, I want to deselect all grid lines and dimensions without having to SHIFT+click each one I want to deselect. So what I'm asking is if there's a keyboard shortcut to deselect all, for instance when the grid element tool is selected in the toolbox, deselect all grid lines in one click, etc.
Not that I am aware of.
I would just set up the Find & Select to select all elements and not grid elements and not dimension.
You can then store that as a criteria set, so you don't have to create it again.
You can also export the criteria sets and import them into other files.
Thank you, your proposal works. I just needed to add the "is not" criteria for the elements I want to exclude and saving it as a criteria set, then selecting the elements. Have a good day, you've significantly saved my time.
