dumsofode
Making "distance guidelines" pinnable to the toolbar?
To clarify, I do think that this WAS a feature before, but it no longer is. To turn on distance guidelines, I cannot simply go into the "view" tab and then turn them on, I also cannot pin the setting to my toolbar. Additionally, I also cannot link a shortcut to toggle this setting. It can only be accessed in the work environment. I would love to see this changed. It is a setting that is very useful in certain circumstances, but it can get in the way at other times. It would be very nice to be able to turn it on and off easily without going into the work environment.
1 Reply 1
You can add the command to any of your tool bars and menus.
It might not be there if you are using your own custom Work Environment from an older version.
So add them to your WE or load a standard WE.
