2016-09-08
		01:29 AM
		2024-03-25
		09:52 AM
			Aruzhan Ilaikova
2016-09-08 03:07 PM
rm wrote:The Pet Palette behavior is the same, but it is not a right-click, simply click on the Wall to get the Pet Palette to appear. (A right-click should bring up the Context Menu.) Make sure only a single Wall is selected before clicking. This is the same in AC12 and AC20. If the Pet Palette is not appearing, then check Work Environment > User Preference Schemes > Dialog Boxes and Palettes to see how the behavior of the Pet Palette is set.
I drew a few walls and try to right-click to bring up the pet palette that used to let you add a curve to it along with other modifications. I can't get the wall tool to work that way it did in AC 12 to save my life.
2016-09-08 05:53 PM
2016-09-08 08:59 PM
David wrote:Hi David,
Roofs: AC20 has the Multi-Plane Roof in addition to the older Single-Plane Roof, so there have been changes to the Roof Tool you will want to learn.
2016-09-09 07:50 PM
