I am trying to get a Web Reviewer server running. Some people have errors while accessing it, and I can't find a correlation between OS or Browser being used. It doesn't appear to be anything to do with Java VM version or JavaScript not being enabled. I'm not sure if it could be a permissions problem on the server.
I got one of those polls running for 14 days here, but it would be more useful if you could post what OS and Browser you are using and whether you are getting access errors.
So far I have had two people using Opera that haven't had any problems, so maybe that is the answer. The results for Firefox and IE are mixed.
I have an example file from ArchiCAD here. When I get this up and running there will be password protection using ASP. Then I can allow write access to the server to use the direct FTP upload button rather than the email thing.
http://test404.damnserver.comOf course you'll need the Sun Java VM to be able to see it.
Thanks for any help..
