General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Undo - Redo - Beachball of Death - Crash
kwpoulsen
This happens often enough that this really needs to come to someone's attention.  It's often helpful to undo/redo to select elements that you've worked on recently.  Today I'm creating a site plan from a Civil .DWG. I'm tracing splines (not very complex.Maybe 6 segments) using the polygon tool.  My undo limit is 20. So, when I get to about 13 actions, I undo/redo to select them.  I've learned to slow way down for Archicad so it can catch up (relative to Archicad 12, which was very responsive). But, I undo about 10 times and get the spinning beachball of death.  The only thing I can do at this point is wait for Archicad to crash.
This happens in many projects, doing various commands, on more than one computer. This is such a simple and common activity that one would think that Archicad could handle it seamlessly (like it did in Archicad 12). Not the case.
Can someone please chase down the cause of this bug and fix it?  It's getting old.
0 REPLIES 0
