yesterday
We all fairly recently saw some life in the Wishlist process. There was a big "spring cleanup" this year.
The Wishlist is now filled with 10 pages of wishes but all I see is "open" and "upvoted" wishes. There is not a single wish that is being "under consideration" or "on the roadmap"
The same applies to the German "Wunschliste" btw.
What exactly - if anything - is Graphisoft doing with these Wishlists?
yesterday
Hi pr3,
I can tell you that our product managers are looking into this, however since it is a quite a load of wishes it is a time consuming task. Also, they want to make sure that the clean-up wishes are considered thoroughly. It is not an easy task as it requires several people to contribute, who have their own projects / responsibilities to take care of in parallel. Admittedly it is a bit slower than I have expected but I will make sure that the process will be a steady progress and we will get through all of them.
yesterday
Let me check back in a few months time to see if you start to listen to feedback from the frontlines and give at least one wish a "under consideration".
I set a kind low bar here.
