2009-01-24 09:22 AM - last edited on 2024-04-26 11:22 AM by Aruzhan Ilaikova
Solved! Go to Solution.
2024-10-07 09:37 AM
For those who have difficulty distinguishing the original launch icons, we’ve introduced new alternative icons that prominently display the version number for easier identification. You can find all the details about the icon changes in this Knowledge Base article:
Please read it carefully, as the previous solution some of you used is incorrect and may cause Archicad to mistakenly be flagged as a pirated version. To avoid issues, kindly follow the guide in the article.
Thank you!
2017-08-03 06:39 AM
2020-01-07 01:47 AM
2020-01-07 01:48 AM
2020-07-11 12:12 PM
2022-10-03 04:22 AM
It took us more than a year to realise that we did not post the replacement logo for Archicad 25, so here a double post for both AC25 & AC26... enjoy!
https://macinteract.com/Archicad-25-replacement-icons/
https://macinteract.com/Archicad-26-replacement-icons/
2022-10-03 04:27 AM - edited 2022-11-03 06:04 AM
If only Graphisoft would do this. 🙄
25 & 26 are so similar it is ridiculous.
At least 24 & 25 had a different shape.
Barry
2023-06-13 06:12 AM
Just for completeness sake, it seems GS might finally consider a proper solution and save us the trouble each year...
2024-01-30 06:29 AM
Hurrah another version...
https://macinteract.com/archicad-27-replacement-icons/
2024-01-30 08:22 AM
Please be very wary doing this. We replaced the icon on one of our macs and it triggered Archicad in to thinking it had been pirated which caused us a bit of an issue with Graphisoft having to explain ourselves.
2024-02-05 04:06 AM
Very sorry about this - we had inadvertently uploaded only the PNG files instead of the actual ICNS
files, thus the replacement would not have worked.
Please note we have now uploaded the correct ICNS files (same link) please try again.
PS > We could not help to also redesign them... 😃
2024-10-07 09:37 AM
Thank you!
4 weeks ago
Thanks for finally providing an offical solution.
For all long-term followers of this thread (since 2009), please note we will no longer produce Archicad version icons as this solves the problem.
However, if you prefer to produce your own graphic / icon, please refer to the following instructions:
https://smart.macinteract.com/icon-creation-tutorial-for-macos-apps/
4 weeks ago
Thank you @Eszter Fulop
Now, if those alternative icons can be saved in the 'Archicad Starter.exe' file (and Mac equivalent) for each new version, then that would be perfect.
We won't have to find and download the new icon as it will already be delivered with Archicad installation.
Thank you.
4 weeks ago
Just FYI, when updating Archicad you have to replace the icon again and recreate any shortcuts/aliases you have of it.
