2005-06-02
		01:55 PM
		2025-01-29
		05:39 PM
			Molinda Prey
2005-06-03 12:53 AM
2005-06-03 04:57 PM
1. Is creating families (or blocks) is easy enough to do? do i just use extrude, blend and so forth? are they fully parametric in the project?Programming in GDL or drag'n drop drawing elements. The first gives full control, the latter is easier, but static.
2. Is information in the project can be controlled from any place? i.e, can I change the model on the sheet or change a door in the door schedule and the change will carry through?From most places, but not all. schedules -> only partly
3.how do you find documentations in Archicad? if you used Revit and can compare....Don't understand the question
4. is it possible to control depth in elevations and sections with more than one plain? (there is no depth control in Revit atm)Yes
5. If you used Revit before, why are you using Archicad now?Not applicable to me.
2005-06-06 11:20 AM
2005-06-06 11:43 AM
eldados wrote:From the limited experience I have with Revit, it's documentation process is quick and direct.
thanks for the reply guys, running the demo atm trying to get a grip on AC,
I seem to be missing somethings![]()
is it possible to draw a wall and enter length just by typing? do i really have to enter it in the box??
what about keyboard shortcuts? it's looks very complicated if i just want to trim or extend walls right now... (I'm a newbie so be gentle)
Stefan, according to the list of software you used, you know Revit, how do you find documenting a project in AC compare to Revit?harder, easier, more complicated?![]()
thanks again
2005-06-06 07:12 PM
stefan wrote:No experience on Revit, but I am doing full projects in ArchiCAD for the last decade. The main advantage over anything else is the change control and the publishing - if set up properly - is a blessing.
The deciding factor for me would be the ease of making modifications to the project and for that Revit is hard to beat. But ArchiCAD is capable and there are examples enough of users finishing complete projects in ArchiCAD, without any additional CAD-software.
2005-06-07 09:18 AM
Djordje wrote:Experience is often worth more then software features.stefan wrote:No experience on Revit, but I am doing full projects in ArchiCAD for the last decade. The main advantage over anything else is the change control and the publishing - if set up properly - is a blessing.
Unlike Stefan, I have never found a problem in modifications to the project using ArchiCAD, just the opposite. Maybe I did too many projects?
2005-06-09 03:16 PM
stefan wrote:I would say - always.
