General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
switching from revit to archicad
hi, i'm new to archicad... kinda. i used version 6 ages ago but have been using revit since 2006. i thought it would be a piece of cake getting back into archicad but find i'm mistaken. i've done the basic interactive training but have difficulty doing the exercises on my own. could be because i'm trying the same approach as in revit, which doesn't work, obviously.
anyone here made the switch? any tips on how to un-revit my thinking?
117 REPLIES 117
Dennis Lee
greenfin wrote:
oreopoulos wrote:
Î¥ou will not find storefront windows in international version of Archicad, only in the US.
oh. that's very strange indeed. curtain walls have been around for decades and we (europeans, as well as the rest of the world) have been designing buildings with curtain walls all the time so how do archicad users get around this limitation?
I've never had the curtainwall and storefront in AutoCAD the last 15 years I've been using it. Not even a regular simple wall tool. I did work on skyscrapers with it though.
I think AC as with all other tools, is evolving, and becoming more and more complete. It is changing the way we document buildings, few steps at a time. Even with V12, there won't be a specific automatic tool to do a lot of things, but that's life. I'm sure we can figure out how to get the necessary information to the client / contractor.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
My grandfather used a horse to move around towns. It did the job. I wonder why we have those stupid things called cars and guess what you are paying to buy them. I guess you did your job before pc era. So i dont see your point. You dont see the goal. To totally have in control of the whole building process.
AC is evolving slower than any other competitive program. The problem is they think that if they develop fast enough then they might reach a position that users will not need more functions (a ripe product) and they wont upgrade.
I am 1000% certain that this cannot be the case. The product is so far away from letting you describe the whole building and when it reaches that goal, computers would be so advanced that we would have much different needs.
What i think is the right pace?
Well take all 3 previous releases and put them in one.
Then yes , that would be a healthy development pace.
Dennis Lee
My point was that you can describe curtainwall buildings without curtainwall tool. It's pretty simple.
Also, autocad was and still is only pc.
Windows 10 x64
Since ArchiCAD 9
yes. it could be done with a pen and paper napkin as well. the point is, archicad is a BIM software and if you have to 'fake' curtain walls by detailing it in 2D then that defeats the whole purpose of BIM.
i think a curtain wall is a basic wall type, even more than the composites and can't understand why archicad doesn't have it already. and now with AC12 only the US version will have it?! revit has had it for, i don't know how long, ever since i'd been using it at least. so i took it for granted that archicad would have it, too. if graphisoft wants to keep its market lead (they're still leading, aren't they?) they'll have to step up development.
__archiben
greenfin wrote:
... and now with AC12 only the US version will have it?!
no no no!
the "storefront" objects were previously only available in the USA version's library, although there are many curtain wall type objects in all library versions. AC12 now has a curtain wall assembly tool in the application itself. it will be in all localisations.
yes, it is too late and it can't curve in two directions at the same time.
~/archiben
b e n _ f r o s t
it would be sad if it were the case. archicad is (one of?) the pioneer(s) of BIM and a european company. we don't need autodesk to have the monopoly on BIM as well.
maybe so but buildings would not have changed so much.
__archiben
there are 'curtain wall' objects and window elements in the default library - try a search when you are in a library element browser.
you have two options: using curtain wall 'objects' or curtain wall 'windows'. the first is simply placed in the model as is, the second is placed using the window tool and will form its own wall hole.
when i used to work with curtain walling i chose the former - it ultimately gave me more control over the model. and building the 'hole' in a wall for a curtain wall is actually closer to how the 1:1 model is built as opposed to a standard window or door.
both of these methods are intended to be replaced by the curtain wall tool in 12.
~/archiben
b e n _ f r o s t
yes, i have found them and tried them. my problem with them is that they don't 'act' like walls, meaning they need a host (wall) to be placed.
how do you hide elements in a given view?
say, i have a mesh that i don't want to see in plan view but want to be visible in 3D view. when i change the layer settings to hide it, the mesh disappears in 3D as well. it says in the reference guide that "the settings of any particular layer can be different in the layout book and in model views." does this mean i cannot control visibility in the default views?
Rod Jurich
Set 2 different layer combinations, 1 for your plan view and 1 for what you want to show in 3D.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
I have a T-shaped plan with different widths and wanted to create a roof over it. I decided to use the polyroof method (because I thought it would be the simplest) to do this. This is what it produced (see attached, top). For aesthetic reasons this is not acceptable.
What I'd like is for the two roofs to meet at the peak (bottom picture). I know this can be done as I vaguely remember having done it in ArchiCAD oh so long ago. What I would do in Revit is change the angle of the pitch of the wider roof so that its top coincides with the ridge of the other roof. It seems in ArchiCAD you can't edit the individual sections of a polyroof... or can you? How?
Eduardo Rolon
Any reason why editing the roof polygon is not an option?
Select Roof
right click -> select and activate
move the nodes to create the peak
__
You might/might not have to edit the Z coordinate.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
The old way was to select the roof in plan and command/ctrl click a node on the roof and type or paste in the desired height.
Now you can just do it in the 3D window by selecting the roof and dragging the point down to snap to the peak of the other one. You just need to select the right button on the pet palette.
that's what i was trying to do if by editing you mean moving the nodes around. not only does it entail a lot of work (at least 6 nodes to move for one roof surface), it wreaked havoc on the roof geometry.
if you mean changing the settings, i tried that but you can't change the slope of the individual parts in a polyroof it seems.
i thought it must have to do with using the polyroof method so i tried the polygonal/rectangular geometry method by creating each individual surface which posed new problems for me, not to mention the tediousness of the process.
1. when mirroring a copy, the copy for some reason was longer at the bottom than the original. i checked that both sides had the same slope (45 deg) so it can't be the culprit.
2. there's no option for an overhang
the next option i tried was to create two separate polyroofs but discovered that you can't trim a roof to another roof and had to go and adjust nodes again without much success: the edges where the two roofs are supposed to meet didn't.
ejrolon wrote:
Select Roof
move the nodes to create the peak__
i wish it were that simple. in archicad creating is a walk in the park but you have to get everything right the first time because editing is like climbing mount everest. in revit you can be as lazy and sketchy in creating because editing is so easy and straightforward anyone without prior knowledge of revit (with some basic drafting skills) can do it.
David Maudlin
greenfin:
Make sure to Suspend Groups, Polyroofs are grouped by default.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
while on the subject of roofs, i would just like to confirm if:
1. you can't trim a roof to another roof?
2. you can only trim walls that actually intersect a roof? e.g. a wall 3m high cannot be trimmed to a roof whose base is at 4m?
3. if yes to 2, you have to raise the height of the wall so it intersects the highest part of the roof before you can trim it?
4. you can't pick which roof to trim your walls to?
5. after trimming a wall to a roof, you make changes in the roof's height/slope/configuration, you have to re-trim the wall to the 'new' roof?
6. in revit, you can 'attach' your walls to a roof so that the walls' configuration (height, shape) automatically adjusts to any changes later made to the roof. can you do something similar in archicad?
TomWaltz
1) yes, you can
2) why would a 4 meter high roof trim a 3 meter high wall? If you want to extend the wall, yes, you can.
3) a roof an trim any wall that its plane would intersect, like say if the roof was 3 meters to the left of the wall, but would hit the wall if it extended along its angle.
4) sure you can
5) it depends on which trim command you use. If you use "Trim to Roof" (which allows all of the above to work), then no. If you use Solid Element Operations (which does not allow all of the above to work) then yes.
6) sort of. Solid Element Operations are the closest you get.
Most of these are in the Archicad user manual.
Tom Waltz
TomWaltz wrote:
1) yes, you can
why indeed? sorry, revit-speak. there's only one command for trim/extend in revit and it only says trim on the icon, thus my use of the word 'trim' to mean both trim and extend.
i've read the section on roofs before posing my questions. some things are not covered in manuals/guides and even when they are they are not always clearcut and some problems can't simply be foreseen. that's why these forums exist, right?
all my questions were actually about the 'trim to roof' command. i got too involved with it, i ignored other options.
thanks. the group was suspended when i worked on the polyroof. i understand that 'alt + G' is a temporary suspend command so shouldn't the polyroof automatically revert back to its original grouping?
how do you edit a wall profile? i'd like to do a customized wall trim (see attached) for the front facade. from what i gathered you do this in archicad by creating a roof structure to trim your wall to, is this correct? can you work on a wall's profile in elevation/section? i tried this but, unless there's a special command out there that i do not know of, this doesn't seem to be possible.
to do this in revit you first create a regular wall then 'edit profile' it in the right elevation/section. the view will then switch to 'sketch' mode (see attached, right) so that you can draw or edit your profile in 2D. when done simply click 'finish sketch' and you have your wall trim.
Dwight
In cases like these, the Custom Profile should be a wall placed perpendicular to the building wall at the depth you need to express the new element, defining your quoin stack, for instance. Or your brick arch.
To edit a custom profile, sketch over the elevation with a fill to redefine the custom profile, pasting the new fill into the custom profile window or edit the defining fill right in the custom profile window.
Yes, relative to Revit, there's an extra initial step, but each custom profile is saved, so there's payback for repeating situations.
Dwight Atkinson
