Archicad Sample Project - Hillside House
apolgar
Residential⎮Hillside House
How to use the Sample Project?
VERSION: V1.2 │Date: 2020. 07. 08 │ Contact: sampleprojects@graphisoft.com
To explore the virtual building without downloading, try the BIMx Web Viewer by clicking on the play button!
  • Architect: Reload Architects
  • Category: Residental - small scale
  • Floor area: 224 m2 (2411 sqft)
  • Phase: Under construction
  • Version: Archicad 23, 24
How to start Exploring?
This sample project file is a small-scale residential house which is completely free to download and represents the modeling and documentation capabilities of Archicad.
You can download an Archicad pla (Archived file) file created in International version (INT) and a BIMx file as well.
How to open the Archicad project file?
  1. Download the latest Archicad version
  2. Download the sample project file
  3. Open the Archived project file (.pla) in Archicad
  4. Select Read elements directly from archive’ option during the opening process
  5. Start exploring the project by using the pre-saved views on ‘View Map in the Navigator
How to open the BIMx file?
  1. Download the latest BIMx version from the AppStore or GooglePlay to your mobile device (iOS and Android)
  2. Download the BIMx sample file
  3. Synchronize or copy the BIMx sample file to your device
  4. Open BIMx mobile app
  5. Click on the sample project file to be loaded
  6. Start exploring the BIMx file and documentation
What's inside?
  • 3D Models
  • Site Plan
  • Floor Plans
  • Sections and Elevations
  • Schedules
  • Details
  • 3D Documents
  • Rendered images made by Twinmotion
  • Project Presentation Layouts
Legal Notice
The contents are copyright protected.
All rights reserved.
Intellectual Property Rights: Reload Architects, Hungary
Software: GRAPHISOFT Archicad 23, GRAPHISOFT Archicad 24, BIMx, BIMx Lab, BIMx Desktop Viewer and BIMx Web Viewer
By downloading any of the files You accept the terms and conditions of the End User License Agreement.
By opening this Sample Project File ("SPF") You accept the terms of this Agreement between GRAPHISOFT SE and You or the entity, on behalf of which You obtained the sub-license right to the SPF.
The SPF is an Archicad individual project file from which any other file format can be generated (included but not limited to pdf, xls, ifc, dwg).  The SPF is sublicensed to You by GRAPHISOFT SE.
You are entitled to use the SPF solely for your own use and not for any further distribution or resale. The SPF is licensed, not sold, to You and You are forbidden to sub-license, distribute, provide access to or commercialize the SPF or its any component either alone or as part of another product or service. You may NOT sell, loan, distribute, cede, rent or lease or otherwise transfer or assign the right to use the SPF, to transfer or provide access to it by network for commercial use, either in whole or in part. You are expressly forbidden to decompile, disassemble, reverse engineer, translate or reduce the SPF for any purposes whatsoever.
 No part of contents contained in the SPF may be reproduced, used, distributed, or transmitted in any form or by any means without the prior written permission of the copyright owner. These restrictions include in particular the prohibition to use of  any part of the contents to the design and construct of other buildings. You are fully liable and shall compensate all damages to GRAPHISOFT and to the copyright owner in case of and related to the infringements of copyright restrictions set forth herein.
If you don't agree with the terms above, please close and remove the SPF from your computer or device.
