Archicad Sample Projects
Emoke Csikos
This article is a part of a series titled Archicad Quick Tour.
This is a collection of sample projects designed with Archicad. They are all free to download.
M2V HouseāŽ®residential
This project is a residential building, featuring its interior design solutions. It is completely free to download.
To explore the virtual building without downloading, try the BIMx Web Viewer by clicking on the play button below!
  • Architect: A-Architettura, Italy
  • Category: small-scale residential, interior design project
  • Floor area: 224 m2 (2411 sqft)
  • Phase: construction documentation
  • Version: Archicad 25
Scroll down to the end of the article to learn how to explore the project and what's in the project file.
Please also read the legal notice.
Gino 16āŽ®commercial, interior design
This project is a commercial building, featuring its interior design solutions. It is completely free to download.
  • Category: small-scale commercial, interior design project
  • Floor area: 157 m2 (1694 sqft)
  • Phase: design development
Stacked TowerāŽ®residential, large-scale
This project is a large-scale residential building which is completely free to download.
  • Architect: Enzyme Apd, Hong Kong
  • Category: high-rise residential
  • Floor area: 2546 m2 (27405 sqft)
  • Phase: schematic design
  • Version: Archicad 27
Villa PatioāŽ®residential
This project is a small-scale residential house which is completely free to download.
To explore the virtual building without downloading, try the BIMx Web Viewer by clicking on the play button!
  • Floor area: 420 m2 (4520 sqft)
  • Phase: under construction
Hillside HouseāŽ®residential
  • Architect: Reload Architects
  • Phase: Under construction
S-OfficeāŽ®office
This project is a mid-scale office building which is completely free to download.
You can download the Archicad project file of this building as well as the D5 Render Scene project files.
Please check out the Archicad with D5 Render Livesynch video to learn about how to create professional architectural visualization images and
animations. You can also download sample renders and animations.
  • Architect: Graphisoft SE
  • Category: mid-scale commercial
  • Floor area: 1872 m2 (20150 sqft)
  • Phase: Design development
How to start exploring the Sample Projects?
These sample project files are completely free to download and represent the modeling and documentation capabilities of Archicad.
You can download an Archicad pla (Archived file) file created in the International version (INT) of Archicad and a BIMx file as well.
How to open the Archicad project file?
  1. Download the latest Archicad version
  2. Download the sample project file
  3. Open the Archived project file (.pla) in Archicad
  4. Select ā€˜ Read elements directly from archive’ option during the opening process
  5. Start exploring the project by using the pre-saved views on ā€˜ View Map’ in the Navigator
How to open the BIMx file?
  1. Download the latest BIMx version from the AppStore or GooglePlay to your mobile device (iOS or Android)
  2. Download the BIMx hyper-model of the sample project
  3. Synchronize or copy the BIMx hyper-model to your device
  4. Open BIMx mobile app
  5. Click on the sample project hyper-model file to be loaded
  6. Start exploring the model and the documentation within the same BIMx file
What's inside the Sample Projects?
  • 3D Models
  • Site Plan
  • Floor Plans
  • Sections and Elevations
  • Interior Elevations
  • Schedules
  • Details
  • 3D Documents
Legal notice
The contents are copyright protected. All rights reserved.
By downloading any of the files linked above you accept the terms and conditions of the End User License Agreement.
Click to Read the End User License Agreement
By opening this Sample Project File (ā€œSPFā€) You accept the terms of this Agreement between Graphisoft SE and You or the entity, on behalf of which You obtained the sub-license right to the SPF.
The SPF is an Archicad individual project file from which any other file format can be generated (included but not limited to pdf, xls, ifc, dwg).  The SPF is sublicensed to You by Graphisoft SE.
You are entitled to use the SPF solely for your own use and not for any further distribution or resale. The SPF is licensed, not sold, to You and You are forbidden to sub-license, distribute, provide access to or commercialize the SPF or its any component either alone or as part of another product or service. You may NOT sell, loan, distribute, cede, rent or lease or otherwise transfer or assign the right to use the SPF, to transfer or provide access to it by network for commercial use, either in whole or in part. You are expressly forbidden to decompile, disassemble, reverse engineer, translate or reduce the SPF for any purposes whatsoever.
 No part of contents contained in the SPF may be reproduced, used, distributed, or transmitted in any form or by any means without the prior written permission of the copyright owner. These restrictions include in particular the prohibition to use of  any part of the contents to the design and construct of other buildings. You are fully liable and shall compensate all damages to Graphisoft and to the copyright owner in case of and related to the infringements of copyright restrictions set forth herein.
If you don’t agree with the terms above, please close and remove the SPF from your computer or device.
Comments
charghandeh
Reza Charghandeh from Mashhad. Excellent projects
