on
2025-03-26
01:47 PM
2026-03-13
10:09 AM
Andrea Polgar
Dear Community,
If you’ve worked with them before, you’ll know that point clouds bring extremely valuable real-world data into Archicad. However, oftentimes their dense structure can create excessive snap points in a project. This month’s tip explores solutions to this dilemma, originally presented as responses to a forum discussion where @CFS_Mike asked if there’s a way to turn off snapping for point clouds.
While the suggested solutions don’t exactly ‘turn off snap points,’ they do present a few methods for managing interactions and improving your workflow with point clouds. We’ll explore a solution shared by community member @runxel, along with other techniques to better control snaps and element visibility.
While searching for a way to control snapping behavior, @CFS_Mike came across a setting in Input Constraints and Guides.
If you want to explore this menu yourself, you can find it under: Options > Work Environment > Input Constraints and Guides
This panel controls snapping and cursor behavior in Archicad. While it can’t disable point cloud snapping, it offers useful tools for refining snap point workflows.
The key settings available in this panel are:
key settings in Input Constraints and Guides
Another way to refine snapping behavior is by adjusting Snap Point Options, found under View > Snap Point Options. These settings allow greater control over how elements snap to different points along their geometry.
Available options include:
Note: Define your preferred divisions, percentage, etc. in the Snap Point Values Dialog Box.
These settings apply at the segment level, offering flexibility in how snapping behaves when modeling. If you want to learn more about snap points, click here
Snap Point Options available settings
By placing the point cloud in a passive Design Option, you have better control over how it appears in your model.
Use the Fade Environment option to fade the Point Cloud, reducing its visual impact while modeling new elements. This helps maintain reference visibility without it dominating the view.
Como usar o Dissipar Ambiente.
To prevent accidental selection while keeping the Point Cloud visible for reference, use the Lock command by selecting the Point Cloud and go to Edit > Locking > Lock. This keeps the Point Cloud in place while allowing snap points to remain active.
This method keeps your workflow smoother by highlighting relevant elements and locking references such as a point cloud (similarly to the Trace Reference feature)
While Design Options offer the most flexibility by allowing visibility control and locking reference elements, you can also use Graphic Overrides and Layer Combinations as alternatives.
Thank you, @runxel for the insightful tip using Design Options. This solution offers a practical way to lock interactions while keeping the point cloud visibility at hand.
Click here if you want to look at the forum discussion. If you want to learn more about how to work with point clouds, you can also check out this guide here.
Remember to share your challenges, solutions, and insights. Your contribution could be the next Tip of the Month!
Cheers 🎉
