2024-07-12 05:37 PM
After installing the TP build I realized that the GDL coding interface no longer gives suggestions or auto-complete commands (couldn’t remember if this has been similar in beta build). I quite like this feature in ac27 as I don’t need to double check the command syntax. Is it something that was turned off to improve GDL editing performance?
BIM Manager
DKO Architecture - HCMC
Solved! Go to Solution.
a month ago
Hi Minh,
This is a consequence of a bugfix.
When pressing Ctrl+Space the hint(s) will appear again
Marcus
2024-07-13 09:54 AM
It would be good to be able to turn it off and on again - because i hate it, when typing:
"else"
and instead this, after enter, i get:
Of course - one ESC typing - its gone, but what for? A simple "shortkey" should turn it off and on.
Just one little wisch to the GDL-Editors:
What i would like most too would be the possibility to divide the script-Window into two parts like it is possible in Excel or (libre-office Calc) - so that i can simply scroll one part without loosing another part out of sight - still in the same script... like this in Calc:
simulated in Archicad:
For me, it would be a huge benefit.
a month ago
Hi Minh,
Marcus
a month ago
Thanks! I wish for the old behavior to return though 😛 nevertheless, if it was buggy before because of this, then I'm not complaining
BIM Manager
