2024-07-12 06:54 AM
In the new version, some of the most used tools are grouped. But it has changed this option of having a suspend group in the front. Now because it's under the group option, I can access it only if I select any element.
Yes, I can use shortcuts, I can get them from Menubar, but having it in the front to see whether it's active or not helped a lot during working.
2024-07-12 07:31 AM
Don't be afraid to create your own toolbars, menus and keyboard shortcuts in the Work Environment.
A default setup is never going to suit everyone.
Customise it yourself so that you can get Archicad to work in the way that best suits you.
But I agree, the default settings in the Tech Preview are very minimalistic.
Hopefully each language version template will have better setup and preferably with multiple Work Environment profiles to choose from.
2024-07-12 08:25 AM
Hey @Barry Kelly I do have a custom Work Environment created. This is just a suggestion. Even for a base template, I believe it's necessary.
2024-07-12 09:16 AM
I agree.
The Tech Preview should really have a Work Environment set up to show off the new tools and features.
For example the new Keynotes tool.
There is no button for the keynotes palette, you have to go looking for it in the Windows > Palettes menu.
I don't even see it included in the extra toolbars that aren't turned on.
I am assuming that the final version template for each language version will have their own custom setup as they usually do.
