a month ago
Hello,
I can't hide Point Cloud in 3D view through "Hide selections" in Technology preview.
When I use this button, Point Cloud is still visible and in Layers setting that layer is hidden.
Is anyone experiencing the same?
Solved! Go to Solution.
a month ago
It seems there is a problem where the Quick Layers palette does not work in the 3D window.
a month ago
a month ago
Yes Barry is correct plus there is a new hide selection command if you are using the AC27 version
a month ago
Hi, thank you. Yes it’s the same but in my case just with layers where is Point Cloud.
