2024-08-03 10:26 PM
Previously there have been issues with exporting MOD-files with complete classification trees instead of only the ones used in the current project.
I know there were talks about this becoming a checkbox option but cannot find it in the AC28 TP?
What is the status of this?
@James B - any updates?
Solved! Go to Solution.
3 weeks ago
In AC28, we reverted to the previous behaviour where only used properties/classifications are stored, and fixed the behaviour on the UI to avoiding that behaviour appearing as a conflict.
The registry that was used to revert to that behaviour is still available, and supported storing all classifications and properties (which caused file bloat in hotlinks).
We did consider adding this option to the UI, but that didn't make it to this release.
We've also made a number of fixes in how properties/classifications and handled in labels after relinking, breaking hotlinks and nested hotlinks - these fixes should be available in the Updated Tech Preview version and final release.
3 weeks ago
3 weeks ago
Thanks James,
I can understand the reasoning behind the previous change (even though it was disastrous for us) so some sort of toggle switch would probably make sense.
However, I guess that will be a discussion for coming releases.
