yesterday
Regarding the (New in Archicad) window, I've some wishes.
1) The default size is so small to see its contents easily & I had to maximize it manually.
* The default size,
**The maximized size,
2) The Size changes differently for every slide,
3) I suggest the default size to be stretched & adjusted for all slides as follows,
yesterday
Good idea @Mahmoud Qenawi
Did you try to save this into your custom Work Environment? I had the same thought before but not had the time yet to test the Work Environment idea.
yesterday
Thanks @Francois_MCD,
Fortunately, yes it can be saved to my custom WE.
yesterday
Also, I suggest if this window can be closed by pressing Escape as the ordinary dialogue for element settings, for now I've to click the (X) or Close button.
