2024 Technology Preview Program
Graphisoft Technology Preview Program 2024
Problem with Railing object
Gerald Hoffman
I have placed numerous railing objects in a rectangular form. These were selected from included Favorites railings. When closing the railing on the fourth side the railing ends shoot past each other and won't join properly. See screen shots of plan and 3D view.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-5030 USA
2019 MacBook Pro (64GB w/ AMD Radeon Pro 5600M GPU)
runxel
Legend
A well known problem. Nobody thought about that 😄
Official recommendation is to put the end not at a corner, where it would need to miter, but somewhere on a straight, so it's less obvious.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
4 REPLIES 4
runxel
Legend
Thanks. I guess that’s a solution but it would be better if they fixed the problem as it indicates an underlying issue which may also show up in other circumstances when least desired.
cheers,
Gerald Hoffman
Potato Farmer
Mentor
This was reported during the beta period of the railing tool’s initial launch. It was acknowledged but never addressed, then or since.
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-27, M1 Mac, OS 14.x
I've been using Runxel's solution since I discovered this issue.
There are a number of problems with railings.
There's a discontinuity between the location of the setting-out line in 2d and 3d and there's the weird gooseneck connections that the tool always wants to make at corners.
The bug where curved complex profile rails weren't working when the endpoints did not share the same z axis seems to have been fixed though.
Archicad 27 UKI | OS X 12.7.1 Monterey
