Graphisoft Technology Preview Program 2024
Rhino-Grasshopper-Archicad Connection
Illes Papp
The Rhino - Grasshopper - Archicad Connection comes with the following new features:
  1. Hotlink Support - Thanks to the hotlink support introduced, you can create complex floor layouts and distribute hotlinks along curves parametrically.
  2. Beam and Column Options - You can model unique shapes, thanks to expanded Beam and Column options.
  3. Beam / Column Sorter - Sorts your parametrically generated elements into either Columns or Beams, based on their slant.
  4. Rhino 8 Support - Grasshopper Connection for Archicad 28 supports Rhino 8 as well as Rhino 7.
For more information, please visit the following link:
Rhino-Grasshopper-Archicad Connection - Graphisoft Community
Looking forward to having your much appreciated feedbacks, questions and insights.
Illés Papp
GRAPHISOFT Senior Product Manager
Pato99
So it's safe to say Rhino 6 is no longer supported moving forward?
Versions 10 to forced subscription
Metabox Prime-X P775DM2-G (Clevo),
GTX 1060 6GB GDDR5 VRAM - G-Sync,
i7-6700K (8M Cache up to 4.2 GHz),
32GB DDR4 2133MHZ,
512GB SATA 3 M.2 SSD,
Win 11 64
@Pato99 we keep supporting the latest two main versions of Rhino, which is now 7 & 8 and outdates 6, yes.
Illés Papp
