I find that one of the most useful element translations from Grasshopper to Archicad is the Morph Solid, however, I'm not as concerned about the building material definition as the surface attribute. So here's my wish: Can the surface input be added to the Archicad Design nodes where applicable? Otherwise, it all has to be done through Archicad by unlocking the elements which always revert back to the building material when sync-ing again.
