Graphisoft Technology Preview Program 2024
The Wall - Override Surfaces
pIDD
When I apply a surface material override to the wall, the corner of the building doesn't look right. In the older versions, the surface material was applied to the entire surface of the wall.
iScreen Shoter - Archicad - 240718101211.pngiScreen Shoter - Archicad - 240718101249.pngiScreen Shoter - Archicad - 240718101351.png
Because you are overriding the outside surface material, you need to tick the box for "End surfaces override using adjoining walls"
1 REPLY 1
