2024 Technology Preview Program
Graphisoft Technology Preview Program 2024
SOLVED!
The Wall - Override Surfaces
pIDD
When I apply a surface material override to the wall, the corner of the building doesn't look right. In the older versions, the surface material was applied to the entire surface of the wall.
1 ACCEPTED SOLUTION
Solution
Because you are overriding the outside surface material, you need to tick the box for "End surfaces override using adjoining walls"
1 REPLY 1
Solution
