Graphisoft Technology Preview Program 2024
Try to import NCS Drawing Title 27 to AC28 TP
iggiv
Is there any way to import the AC27 “NCS Drawing Title 27” into AC28? I cannot make any of the available drawing titles in AC28 match the settings of the “NCS Drawing Title 27” from AC27.
Attachment 01 shows how I used to make it work in AC27.
Attachment 02 shows the closest I can get to AC28.
Attachment 03 shows the CUSTOM SETTINGS after opening the imported “NCS Drawing Title 27”
Attachment 04 the way it looks in AC27
Attachment 05 is the best way I can make it work within AC28
I tried selecting the Drawing Title in the layout, going to FILE > LIBRARY AND OBJECTS > Save Selection as a “Drawing Title Object,” but when I open it to adjust the settings, the CUSTOM SETTINGS window is blank!
Will this feature be available in the final version?
Attachment 04.pngAttachment 05.pngAttachment 02.pngAttachment 03.pngAttachment 01.png
iggiv
Solution:
I found a way to import the “NCS Drawing Title 27” into AC28. Here’s what I did:
1.Select the Drawing Title in the layout.
2. Go to FILE > LIBRARY AND OBJECTS > Open Object.
3.Save the object and import it into AC28.
Now, I just need to remember how I made the circle in the title not show up.
1 REPLY 1
iggiv
Solution:
