Visualization
3-D Rendering Error
Bob Moore
I keeping getting a warning when doing a rendering "Cannot DEL transformation above top at line___ of file casement_corner 81gsm"
I get about 20 to thirty of these with different numbers in the blank space. If I hit continue it will slowly process the rendering. What does this message mean?
AC 7 - 27
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
you have an error in one of your window parameters you have placed in your model. You need to open the windows with the problems and check the parameters. Often this is due to a fill that is selected that does not exist. If you open the library part of the offending window and look at the line number in the 3d script that is included in the error message you can often get some clues as to which parameters to look at. Good luck.
Dwight
Probably a sliding patio door.
I have just completed a rendering job
http://jonwordenarch.com/Pages/projects.htm
where every patio door - not updated to V9 - had this interpretation error.
- OnyxTreePro trees in case you wondered.
Dwight Atkinson
You might consider turning the warning method off, so you don't slow your rendering down. [work environment/ imaging and calculation -3D interrupt with error message] I know this does not fix your problem but it may make it bearable until you can track down the object problem
