Oswin_N
3D Studio In doesn´t show
Hi! I installed Goodies package, but when I want to use 3d studio it doesn´t show in the File / Interoperability. What should  do?
You don't say what version of Archicad you are using.
Best to create a signature in your profile with some default information.
There was a bug in 26, not sure if it was ever fixed or carried over to 27.
Two solutions.
You can manually add the commands to your Work Environment menus and tool bars.
Or install Archicad again but do not run it.
Repair option is fine if it is offered - you do not have to un-install first.
Then install the goodies, Update Archicad to the latest update (hotfix).
Now you can start Archicad and the commands should be there.
