3D view in AC 13
Ive just installed AC13 and for some reason when i go to the 3D screen and try to pan around, the refresh rate is very slow. Has anyone else experienced this.
Is there some way i can change this
Cheers
6 Replies 6
What rendering method are you using? If it is only happening in OpenGL there is probably some video card/driver incompatibility.
Its when i press F5. Is that the open GL method. In Archicad 12 it worked fine.
I had a $800 video card installed about a year ago. I hope this isnt the problem
Kev
3D Window Settings, 3D Engine selection as below, will be either OpenGL or Infernal (sic) Engine.
Thanks Mate
The 3D setting was set to OpenGL.
Tested it again then and it is so slow that im going to switch back to AC 12 if i cant get it to work.
So sorry guys,
just found out that my video card has shit itself
Thanks for your time once again
cheers
As we are using 13 more widely we are getting all sorts of display errors. The most common one recently has been 2d display - for e.g. losing dimension figures - to the point where we have to turn 2d hardware acceleration off. And that is with recent hardware...
