2016-10-24 10:30 AM
2016-10-24 11:01 AM
2016-10-24 11:06 AM
2016-10-24 11:24 AM
2017-09-14 09:31 PM
2017-09-20 08:16 AM
Dan wrote:I have had this issue in the past, especially associated with Quadro GPUs (for some reason high end game cards seem much more stable for ArchiCAD)
Was just struggling to describe this in the subject title, but the image I hope explains the problem. When navigating in 3D - if I get too near 'things' they get cut. Makes editing certain things impossible.
Is this a graphics driver issue or graphics card setting or bug? Advice greatly appreciated.
p.s. the white squares are me photo shopping out commercially sensitive stuff.
2017-09-20 06:21 PM
2017-09-21 09:47 PM
Paul wrote:Dan wrote:I have had this issue in the past, especially associated with Quadro GPUs (for some reason high end game cards seem much more stable for ArchiCAD)
Issue seems to relate to the way you navigate around a perspective view - if you get closer to something by zooming (eg. with mouse wheel) in rather than by flying the camera with keyboard, this can occur. Also implicated seems to be OpenGL memory churning in the GPU if you have had a busy day.
Workaround seems to be to power off then on again. Again, mainstream GPUs seem to be a lot more reliable than the more expensive 'workstation' GPUs - probably because the same cash outlay will buy you a newer generation card with better specs, more memory, and more regular driver updates
2017-09-28 05:30 PM
2017-11-17 01:25 PM
