2007-07-30 12:26 PM
2008-10-27 06:19 PM
2008-10-27 06:25 PM
Simon wrote:You can customize the device behavior for any application in its control panel . In addition, ArchiCAD has a menu option that reverses all functions to give you either an 'object' or a 'fly through' approach. Look in your View menu for a menu such as that in the attached screenshot. If it is not there, modify your Work Environment to include it.
I just received this 3d Connexion navigator.
it works perfectly in Artlantis, but in Archicad it only rotates the entire model around a point (same as orbit command). I want to fly around like in the explore model function. Is this possible?
2008-10-27 06:25 PM
2008-10-27 06:25 PM
2008-10-27 06:27 PM
2008-10-27 06:39 PM
2008-10-27 07:12 PM
2008-10-27 08:11 PM
Da3dalus wrote:Works fine on my G4 (old dual 1GHz mirror door). Your Dell looks like a "slightly" faster machine, so perhaps not the worst thing in the world for your G4 to have died.
There's still no answer as to whether the 3D Navigator will work on my G4.
2008-10-27 09:50 PM
2011-03-31 06:37 PM
