3d model display problems
Hello,
I'm having issues with ArchiCad 3d model display: surface textures are showing fuzzy on certain sides, model is wobbling while moving around, element edges are not where they need to be.
(Also when exporting model as collada file it doesn't open in Lumion. These problems seem to be related.)
I don't have any similar issues with other ArchiCad files or collada files in this computer. This problematic file was started by another architect who used to work here before me so I don't know why, when or how this problem started.
screenshots:
Thank you for advice.
1 Solution
Ty for answer.
It wasn't too far from project origin. It possibly had to do with classification system. I don't know much about that topic but I found a solution to exporting as collada file just by copying entire model to another Archicad file. So it's ok now.
Go to post
4 Replies 4
Sorry,
the screenshots didn't appear. They are here:
https://drive.google.com/open?id=1Nt8cYZSi0mFQe-DF9O8WipOVm6JCWX5G
Lingwisyer
Guru
Rather than linking image files using [ img ], you can upload images directly to the forum. The forum always seems to have an issue loading external images...
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Is you model far from the Project Origin? If it is, can you check what happens if you move you whole model back close to the Project Origin? Does it handle the issue?
Ty for answer.
